issue in power saving mode.
(Topic created on: 10-31-2018 09:35 PM)
Girishankar
Galaxy Note
 I told problem in power saving mode.
Superb reply I got from the customer support and Samsung partner channel is sir don't use the power saving mode 🤣.. technically genius reply I got 🤣🤣.. any issues found no sir disabled and use it.. in that case wat is the use of releasing feature
3 Comments
admin_
Galaxy Note
Thank you for sharing your concern. The relevant department will serve you better, if you can provide logs/video within 15 minutes of issue occurrence by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports).
Be sure to hit ♡ when you find an answer that works for you. For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
Girishankar
Galaxy Note
Tysm admin for the prompt reply. I have send the logs and screen shot. it was handled by headoffice ppl and without proper analysis they told not a issue.. because I have tested thoroughly and I have show the issue to service centre ppl.. but head office ppl simply closing issue as not a issue
deepakdudhedia
Galaxy Note
https://community.samsungmembers.com/en_IN?projectId=0&meta=#/post?postId=397304
like this plz I need ur support
