how to solve Samsung Galaxy Note9 battery draining problem
(Topic created on: 02-02-2021 07:15 PM)
jayesh321
Galaxy Note
Battery draining issue In Samsung Note9
3 Comments
Galaxy Note
have you checked your software
Dilli
Galaxy Note
There is no solution. Samsung through its updates have done so that user sells the phone to buy new. Typical Apple style.
I have similar issue.
my suggestion to bring some relief is to put apps to sleep in background that you don't use often. put of wifi scan and Bluetooth scan in settings. put of location if you dont use. Hope it helps. if you find slight change do click on 3 dots and mark as solution.
Samsung_Support1
Galaxy Note
Dear Samsung Member,
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
