elecom Qi wireless battery charger - W-QS01BK
(Topic created on: 11-23-2022 02:38 AM)
AbdulShakoorilyas
Beginner Level 4
Galaxy Note
Specifications Supported devices: Apparatus corresponding to Qi standard wireless Charge of 5W Input: Up to 5V/2A Output: Up to 5W Input terminal USB Type-C female (Qi pad part) The body Dimensions About W72mm X D10.5mm X H136mm The body weight About 123 g (we do not include adjuster) Use temperature span 0 degrees Celsius - 40 degrees Celsius Use humidity requirement 10% - 85% The certification standard Qi LED emission color Wait: Out of lights out/Charge: Red lighting/Charge completion: Blue lighting/error: Red blue blinking ※Color of LED may not change at the time of Charge completion depending on model. This color of the body < Black > Cable Specifications USB Type-A toTypeC cable Cable length About 1m Cable color < Black > Accessories: Cable adjuster Term of a guarantee One year Guarantee prediction areas Japan Others Charge adapter needs the purchase separately
