04-22-2020 03:44 AM in
Galaxy Note- Mark as New
04-22-2020 06:13 AM in
04-22-2020 06:37 AM in
04-22-2020 06:25 PM (Last edited 04-22-2020 06:37 PM ) in
Galaxy Note1.Charging USB cable may be damaged.Try with other cable
2.Try to charge your d evice with official samsung charger
3. Charging port may be damaged.
4. Battery may be damaged
5. Weak power source
6.Have you enabled the fast charging option?
If above reasons are not the issue i think you sholud wait and visit a service centre after this lockdown.Hope it helps you
04-23-2020 07:41 AM in
04-28-2020 05:36 PM in
Galaxy NoteDear Samsung Member,
To resolve "charging issue " kindly follow the given below steps:
1)Check physical condition of USB cable:-Check your charging cable (USB cable) for physical damage such as wear and tear, bent prongs etc
2) Safe mode:-Power off the device > Press and hold the Power key for one or two seconds to turn on the device > When the Samsung logo appears, press and hold the Volume down key.
Note :-To exit safe mode restart the device .
3)Reset the device: -Kindly create data backup of your device via SMART switch mobile application or http://www.samsung.com/in/support/smartswitch pc suite.
Tap on Settings>Tap on General Management>Tap on Reset.
If the issue still persist, kindly register your concern in Samsung Members app (Samsung Members app > Get help > Feedback > Error report/ask question).
Note: Please send device log files within 15 minutes of issue occurrence along with the exact issue details.
