battery reverse charging in Galaxy Note 9
(Topic created on: 04-16-2020 10:49 PM)
monark19
Galaxy Note
Battery reverse charging after reaching at 94%and above. And it keeps decreasing when it is connected to charger. Did anyone have this problem?
16 Comments
Not applicable
Galaxy Note
go in cooler areas it will start charging up again
Not applicable
Galaxy Note
the battery will not charge if your environment is too hot aur cold
monark19
Galaxy Note
ohk thanks buddy
monark19
Galaxy Note
did you know Samsung have removed slow mo flicker removing feature
Not applicable
Galaxy Note
no its present till yet
hedgehog
Galaxy Note
reverse charging won't work when phone is charging itself it can divert battery power only in one direction either from charger to phone or from phone to other device
it'll not charge when phone is charging
and also adjust the battery % when the charging should reduce or stop
also keep away from sun avoid any network like bluetooth wifi data from running while reverse charge is working to avoid load on battery thereby heating it up direct battery power only to device being charged because networks to maintain signal load up battery
try not to do that and keep in cool place 👍👍👍👍👍
Not applicable
Galaxy Note
ab dhakan mien uska solution phele hi de diya ab kuch aur mat bol dhakan😂
monark19
Galaxy Note
mapledew I have Note 9 not S10 series or Note 20 series
Not applicable
Galaxy Note
daakan
