battery drain issue
(Topic created on: 03-26-2019 12:40 AM)
Parthvyas
Galaxy Note
Hey Samsung i am getting battery drain issue on my device its note 8 with one ui updated
Plz fix this issue
3 Comments
skcfnet
Galaxy Note
same happened with my J7 Prime after Update
sarfarazahmed
Galaxy Note
Uninstall all unuse apps
Restart the phone
Still having issue
Go to service centre
vinayshah
Galaxy Note
Go to settings, device care, battery and click on battery usage and see which app is using the battery too much. On experimental basis, delete those apps ans see how your phone performs. If the problem still persist even after removing those apps then try with hard reset of your phone and even if that doesn't work please visit service centre. If this solves your problem then click on the 3 dots and select "accept as solution".
