battery drain and phone update issue
(Topic created on: 11-27-2017 12:27 AM)
shiv7688
Galaxy Note
facing some issues with the battery drain and also sticky screen sometimes. have to restart phone couple of time in a day. When Samsung is going to release the software update fixing the bugs and with latest security patch????
any1 has any idea?? please help.......
3 Comments
Blade1
Galaxy Note
never. even the Note 8 is not updated.
talhaa1
Galaxy Note
even im having battery drain issues, go to the Samsung service centre, and they'll reinstall the software. if that doesn't work they might replace it for you. And check now there should be a couple of updates out
SamZykGabe
Galaxy Note
I've noticed that since I purchased my note 8 something happens it also easy to drain even if I didn't use it
