Highlighted
Hi guys...,kindly help me, im using note 9 for past 1.5 yrs... performance is very good but it has the heating issue and battery drain is drastic.., what can i do for resolving the issue.. kindly help me guys...any note 9 users facing this issue?๐Ÿฅบ
5 Comments
Highlighted
If you face both heating and battery drain, it might be because the battery is going faulty. I recommend visiting the service centre after this corona pandemic goes away to ensure proper running of the device. Stay safe!
Highlighted
Restart
Hold power+volume up+ bixby together
Menu will popup, using volume keys go to clear cache
Do it
Highlighted
Will it leads to loss of app data or any data in mble?๐Ÿฅบ
Highlighted
Dear Samsung Member,
To resolve  "battery drainage"  issue please click on the link below:
http://www.samsung.com/in/support/skp/faq/1101689
 And to resolve "over heating issue" please click on the link below for details:
https://www.samsung.com/in/support/mobile-devices/why-the-heating-issue-occurs-in-mobile-device/
If the issue still persist, kindly register your concern in Samsung Members app (Samsung Members app > Get help > Feedback > Error report).
Note: Please send device log files within 15 minutes of issue occurrence along with the exact issue details.
Highlighted
