Eshangill
03-16-2022 11:47 PM in
Galaxy Note
Koi bhai help krdo Mera note 8 h John kuch time k bad khud bad khud restart ho jata h
5 Comments
MrUnknown837
03-16-2022 11:53 PM in
Galaxy Note
Go to setting -> Device Care -> Battery Section Opr 3 Dots hon gy udr check kro wahan se maybe select howa ho
Eshangill
03-17-2022 09:14 AM in
Galaxy Note
Bhai wo check kiya h wahala sy nhi h
innovativeAR121
03-17-2022 01:01 AM in
Galaxy Note
Bro it's sometimes 3rd party apps so factory reset it or otherwise its software problem so hard reset by service centre
LaLa007
03-17-2022 03:31 AM in
Galaxy Note
Software problem....plz reset your phn first remove ur google account, then dont update ur phn software
fff111333
03-25-2022 04:12 AM in
Galaxy Note
Bluetooth does not connect to other devices
