Maliksahib
05-07-2023 11:51 AM in
Galaxy Note
Hi,
How long should note 20 ultra 5G,s battery last if you only use WhatsApp for operational usage and YouTube sometimes?
2 Comments
salmanul
05-07-2023 12:55 PM in
Galaxy Note
Samsung is known for its well-optimized software that can help you get better battery life if you manage your settings well.
wahabu
07-09-2023 12:52 PM in
Galaxy Note
Try to change your display settings to standard in motion smoothness .. check background battery usage to see which app is draining battery
