Samsung galaxy note 9 display problem
(Topic created on: 04-17-2023 09:27 AM)
Mohanfromtn
Galaxy Note
My samsung galaxy note 9 display problem green screen issue how to fix it any one help me
Like this
2 Comments
Galaxy Note
There is no fixing for that except visiting services center and get your display panal changed.
cs-member11
Galaxy Note
Dear Samsung member,
Please check your device in safe mode.
Step 1: To enter into Safe mode:
Power off the device>Press and hold the Power key for one or two seconds to turn on the device>>When the Samsung logo appears, press and hold the Volume down key.
Note: If your device functions correctly in Safe Mode, it is most likely that the issue lies with a 3rd party application that can be uninstalled to resolve the problem.
To exit the safe mode, restart the device.
Step 2: Check for Software Updates using the steps:
Settings >> Software update >> Download and install>>Check for software
update >> If Software update available>>Download>>Downloading updates>>Install now.
Step 3: Please reset all device settings using the steps:
Apps>settings> general management>reset all settings( Delete just settings) / Factory reset( Delete complete files, apps etc)
Kindly create a data backup of your device via the smart switch mobile application or http://www.samsung.com/in/support/smartswitch pc suite.
Remember the google password before resetting the device because it is required during the initial setup.
If you do not remember then advise to reset (Forgot password) the google account.
For this; Open Gmail (https://accounts.google.com/servicelogin)>>Select forgot password>>Select "try another way" like mobile number, security question, etc.>>Select Next.
If your issue will be not resolved after performing the steps, kindly visit our service center for the physical inspection of the device. Please click on the link mentioned below to get a nearby service center to your Pincode: http://www.samsung.com/in/support/servicelocation/
Warm regard,
