Samsung galaxy Note 10 s pen problem
(Topic created on: 03-27-2023 10:45 PM)
Singh_Jot
Galaxy Note
S PEN 🖊 NOT WORK AFTER LAST UPDATES, NOTE SERIES S PEN RELATED ISSUE THEN SAY RE REST AGAIN 😴, how much more customers have same issues?
2 Comments
cs_member8
Galaxy Note
Dear Samsung member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same. And please follow the easy troubleshooting steps which might help to solve the issue.
1. Reason: Due to cases or covers with magnetic material.
Solution: If a magnetic case or cover is attached to the device, the device may not recognize the S Pen actions and the S Pen may not work properly. In this case, kindly remove the magnetic case or cover and then use S Pen.
2: If you use the S Pen at sharp angles anywhere on the screen, the device may not recognize the S Pen's actions. So please do not use an S Pen at sharp angles.
Also, perform the below troubleshooting steps for s pen connection:
1. Insert the S Pen into the slot to start the connection.
2. Open the notification panel by sliding down from the top of the device.
3. Expand the options in the notification panel.
4. Slide the notification panel to the left.
5. Tap the S Pen remote.
6. Tap it again to reactivate it.
In order to Reset the S Pen kindly go through the below-given steps:
1. Long press the S Pen remote icon.
2. The S Pen remote settings screen will automatically open.
3. Tap the More options icon.
4. Tap Reset S Pen.
Or you can also access it through Settings: Tap Settings > Advanced Features > S Pen remote > S Pen > More option > Reset S Pen.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
Thank you for writing to us.
Samsung Customer Support.
Singh_Jot
Galaxy Note
Ok bro, say next what do
