Samsung Note 20 battery charging issue
(Topic created on: 10-23-2020 01:49 AM)
Niharshah
Galaxy Note
Hi,
I have purchased the Samsung note 20 from samsung online shop. I just wanted to know the average charging time for this phone to go from 0-100% from community members who are using Note20.
As my samsung note 20 takes more than 2.5 hours to.full charge. I have reported to samsung service center and they are telling that this is because i have installed more apps than which came default out of the box. So i need to delete and then check.
Can anyone please help me.with this. I have also complaint to Samsung support team and they are trying to find the reason.
Help would be appreciated
Thanks
Nihar Shah
6 Comments
trendygautam
Galaxy Note
it is 1.15 hours with Super fast charging
Niharshah
Galaxy Note
thanks for your reply but is it your hands on experience ?? as samsung service center is not agreeing to the same
trendygautam
Galaxy Note
Yes it is my hands on review
cs-member13
Expert Level 4
Galaxy Note
Dear Samsung Member,
To resolve "slow charging" issue kindly follow the given below steps:
1) Check charger functionality:-Request you to check the charger functionality with a different device or try to charge the same device with a different charger.
2) Reset the device: -Kindly create data backup of your device via SMART switch mobile application or http://www.samsung.com/in/support/smartswitch pc suite.
>>Tap on Settings>Tap on General Management>Tap on Reset.
If the issue still persist, kindly register your concern in Samsung Members app (Samsung Members app > Get help > Feedback > Error report) along with Screen-shots(time taken to charge). This will help us to further investigate and resolve your concern."
Note: Please send device log files within 15 minutes of issue occurrence along with the exact issue details.
Niharshah
Galaxy Note
Hi ,
Thanks for the response. I will surely share the screenshot by tomorrow. can you help me how to take device log files ?? as I am unaware about the same
Niharshah
Galaxy Note
I have already done the above all debugging steps
