11-10-2019 11:04 PM (Last edited 11-10-2019 11:07 PM ) in
Galaxy Note- « Previous
- 1
- 2
- Next »
08-29-2020 04:24 AM (Last edited 08-29-2020 04:24 AM ) in
Galaxy Note- Mark as New
04-02-2020 10:17 PM in
Galaxy NoteHii Vinay, have you Visited samsung store and found any solution
04-17-2020 01:22 AM in
04-18-2020 03:56 PM in
05-03-2020 04:25 PM in
Galaxy NoteSame with mine, after update it turns to faded screen then green. It goes back to normal if you turn off the screen for few minutes . Once i watched videos in few minutes the problem occurs again. You can still hear the audio but screen is green or faded yellow. If you swipe for print screen, the capture is normal. The problem is worst once you watch video or if there are transition of a photo to another. It is very annoying since i keep turning on and off to make back to normal. Another recent software update from yesterday but it is only for security and cam updates, and still have the same problem. Expensive phone for a lemon
04-28-2020 01:21 PM in
Galaxy NoteIt is a software bug so many users facing this problem, this bug will be fix in upcoming updates.
05-04-2020 09:23 AM in
Galaxy NoteI have the same problem. From day1 I bought Samsung note9, I am keep facing many problems. Now, my screen is behaving abnormally..Seems this is purely display problem. I bought this mobile in India..When I am keeping display at lowest, then only I can use this phone..If I increase display little more, then screen going blurr with yellowish color and lines..
Understood that I should disconnect completely from Samsung.
08-29-2020 04:18 AM (Last edited 08-29-2020 04:19 AM ) in
08-29-2020 04:20 AM (Last edited 08-29-2020 04:20 AM ) in
- 1
- 2
- Next »
