S-PEN BATTERY DRAINAGE AND DISCONNECTION
(Topic created on: 05-07-2020 04:40 PM)
IamMANU
Galaxy Note
From past 2 Week Im Facing some Problem regarding my SPEN in my Samsung Galaxy Note 10 Plus.My Air Gestures are ON.My SPEN battery was also full.But when i take out SPEN for any screencapture or anything The error come up that SPEN Disconnectes.Than I again Pull back in but show Connecting that Shows erro again that reconnection Failed.I Have reset the SPEN N number of time But same issue i happening.Its seems that Its a bug fron start as i Use SPEN very less but currently when i pull it out i have noticed this errors.I think the Battery in SPEN is the issue has i have noticed that It is showing 100% when SPEN is inside the phone but when i pull it out the battery in momemt goes back to 10% and spen get disconnected,And when i pull back the spen inside i got an error "RECONNECT YOU SPEN".This issue is really frustrating.Tye screenshot and screen recording I have shared with You Kindly Look
(THE PROBLEM WAS SOLVED WITH SIMPLE SPEN REPLACEMENT UNDER WARRANTY)
17 Comments
IamMANU
Galaxy Note
I Have faced this issue way back year ago when using NOte 10+. And Service Centre changed the spen in warranty.
abdqawiqaid
Galaxy Note
Same problem
abdqawiqaid
Galaxy Note
Same problem with my Note 10 plus
IamMANU
Galaxy Note
SAMSUNG CARE WILL REPLACE IT ,IF UNDER WARRANTY . U HAVE TO BUY NEW SPEN IF DEVICE IS OUT WARRANTY
Mujahideen
Galaxy Note
I am facing the same issue
IamMANU
Galaxy Note
Replace It with Care...issue is in pen
Mujahideen
Galaxy Note
How much does it cost
NishitMehta
Galaxy Note
Around 3150/- At the Service Center
