Note20 Ultra mobile data doesn't work when wifi disconnects
(Topic created on: 05-02-2023 11:14 AM)
Aditya_Anurag
Galaxy Note
After upgrading to Android 13 few months back, I have observed that Note20 Ultra doesn't switch to mobile data automatically when wifi disconnects, as in effectively to provide data access.
Mobile data always stays on along with wifi and whenever wifi disconnects, I am forced to toggle airplane mode to get mobile data working.
Is this a known bug or am I the only one?
Any solutions?
Moreover I'll port to Airtel since there is no hope for Jio5g.
8 Comments
LameNinja07
Galaxy Note
I do the same on my S21FE
Suvo99
Galaxy Note
You can try this "Mobile Data Always On" in Developer Option to see if it works.
Aditya_Anurag
Galaxy Note
I have tried with this too, no effect sadly.
Suvo99
Galaxy Note
Then...I think this is a bug..
kpshivas
Galaxy Note
If you have dropped your note 20 multiple times, I suggest you to get the handset checked for the antenna portion of the motherboard.
I am facing the same issue, and the Samsung service center showed me my network graph as proof.
They suggested to get it repaired, which is tough though. (90% success chance)
If not repairable then they might suggest to replace the motherboard, which is definitely not economically advisable for a 3 year old phone.
I haven't done the repair part yet.
Will update once I do by the end of this month.
Aditya_Anurag
Galaxy Note
Safe to say I have dropped it multiple times but the issue came up with OneUi 5.
I still have my Care+ for 2 more months so if it works for you, I'll get my handset replaced or atleast get all costs covered.
I'll await your next update!
Galaxy Note
Hey, i got my phone repaired. It works as good as any other latest phone.
Galaxy Note
One thing to note is that, they took almost 2 weeks as the spare part wasn't available.
