Highlighted
I've been facing idle battery drain of about 10% overnight. I want to know about you guys, how much drain are you facing.
7 Comments
Highlighted
its very bad for me when comparing to you.. it took around 32% and additionally screen took 22%. Team we need a bug fix here. i was using s8 earlier which give me a perfect backup where it is missing in note 10.
Highlighted
In your case it's even worse.
We need a fix for this drain ASAP. God knows if samsung is even aware of this or not.
Highlighted
Highlighted
Is this note10 or note10+?
You are getting pretty good battery!
Highlighted
yup. its very decent and backup seems to be very good. Just i charged 100% and i hve used only s memb app for 10 mins niw it turns to 96%. i think its issue with my phone.. let me double check it
Highlighted
bhailog abhi toh new model ane do like s11 fir toh kafi sari problem aajayegi mobile mein vai update.
Highlighted
hahaha pata nahi fir toh kya hi hoga
