Note 20 ultra battery issue
(Topic created on: 12-13-2022 11:19 AM)
aykhaan
Galaxy Note
Battery has started to drain after the last update. Also charging starts as "super fast charging" but then the wording change to "charging" however the time to complete charging stays as what initially showed with "super fast charging" .
The battery drain has sped up and it is frustrating. Kindly fix it.
2 Comments
Saadi121
Galaxy Note
Yes, after the update, only charging and battery is drained a little faster, and
Bro, you must turn off sync function location and don't use tiktok youtube too much
shabahat
Galaxy Note
Same issues on S21 Fe after update..
