Resolved! Solved
Note 20 ultra batter charging issue
(Topic created on: 05-03-2022 07:38 AM)
pradeepsharmaji
Galaxy Note
Dear all,
My note 20 ultra 5g is just 6 months old..and the battery with super fast charging feature @25 w takes too long time to charge..at times it predicts the battery to charge within 60 minutes but it takes 120 minutes..and at times the charging got stuck and doesn't go agead rather the battery percentage starts decreasing ....kindly support
Resolved!
19 Comments
Ab_Heartsy
Expert Level 3
Galaxy Note
Ah.. okay good to know they improved😊👍🏼
MuzikD
Expert Level 3
Galaxy Note
Well, i want to ask a few points:
1. Hows the temperature there? Higher then 42 degree?
2. Is that same happen during night charging?
3. At what percentage it got stuck?
4. How did you update your mobile, via OTA or smart switch?
Then only i can come to any conclusions. Thanks
Galaxy Note
First of all thank you sir and here are the replies to your questions....
The temperature is around 42 here at rajasthan...during night it is not happening...at sround 70% it gets stuck sometime but not always...i updated it via OTA..
MuzikD
Expert Level 3
Galaxy Note
Cool. Now, i think you have your answer...
Note 20 Ultra stop charging when temp raise to 40+ or mobile temp upto 50 max... It wont charge. You can feel that heat in your hands. Same happened with me too.
I suggest you to charge at night to avoid any heat damage to phone. Thanks
Galaxy Note
Ok fine sir...thank you so much ...I will definitely follow your instructions...
MuzikD
Expert Level 3
Galaxy Note
You can mark it as solution by clicking 3 dots on right side of comments. Thanks
Galaxy Note
Solution accepted
MuzikD
Expert Level 3
Galaxy Note
Thanks 🙏. I visited rajasthan last month. Alwar, jaipur, jhodpur to Jaisalmer. Awesome places.
Galaxy Note
I belong to ajmer ...you are welcome
MuzikD
Expert Level 3
Galaxy Note
Nice and cool palce as compared to other districts. Thanks 👍
