Note 20 Ultra battery draining very quickly even after replacing battery.
(Topic created on: 06-17-2024 06:24 PM)
suuuuuca
Beginner Level 3
Galaxy Note
As u can see the phone lasts around 10hrs on full battery. Even in idle mode it's draining a lot of battery. I've tried almost everything internet suggested except factory reset.
I got my battery replaced just over a week ago, so the adaptive battery should be doing it's thing.
5 Comments
Abhisteza
Beginner Level 4
Galaxy Note
This major problem is seen in my device too. This is due to the update made by samsung on april new OS update  6.1.
I observed Battery drain even when on sleep.
Over heating while charging and on normal use.
doesn't charge if Fast charging option is enabled.
I think we need to go for a new one rather than Samsung.
suuuuuca
Beginner Level 3
Galaxy Note
My battery drains almost 30% every night. I'll probably just start charging it overnight at this point, as it's a new battery and surely the battery life can't get worse than this.
And I'm facing the same issues while charging as well.
I'll probably switch to a different company too, cuz this is really frustrating
cs_member10
Galaxy Note
Dear Samsung Member,
As per your query, you have already done the possible troubleshooting steps on your device, so we would request you to please reset your device once after taking data backup might be your issue will be resolved, if still facing the issue, kindly visit the service center and inspect your device with the technical team end, they will provide you with all the information in a better way after inspecting the device physically.
Sameer
Galaxy Note
I have tried to address this issue in my video ...
https://youtu.be/DXM7pdW5a-w?si=_uL2LE-EYk5c8lY8
Make the following changes and wait for 2 weeks, post making all changes ...so that it studies the usage patterns and later battery life is enhanced ...
This you tube channel is only about Samsung and will cover some exclusive content (not covered by Any channel) ...
If you like the video, please subscribe and hit the bell icon for all future updates
EG-Minhaj
Galaxy Note
Same happened with me too
