Note 10+ battery issue
(Topic created on: 10-02-2019 12:06 PM)
kushagrasharma
Beginner Level 4
Galaxy Note
I upgraded from Note 9 to Note 10+ and I am really disappointed with the battery life of Note 10+. It drains very fast, get heated up quickly. I still have my Note 9 with me and it lasts longer that Note 10+ in comparison despite having a smaller battery. I have tried quite a few options to save battery life like switching off Always on display, reducing the display resolution, putting unused app to sleep, etc but nothing actually works. Anyone else having a similar experience? Can someone from Samsung look into this.
5 Comments
allol
Galaxy Note
agree and same with me 😔
alrayhi
Galaxy Note
im sure next updated will fix it . also you check on YouTube how calibrate battery on samsung . might helps you
Subinbabugeorge
Galaxy Note
agree and same for me
TheExpendble
Galaxy Note
try to disable all bixby apps using this software. CCSWE.
i am getting close to 5h to 6h SOT with normal usage of all day wifi, BT, games, videos, YouTube, Aod etc
also make sure below settings are applied:
1. Wifi Power saving mode to ON
2. Adaptive Battery to ON
3. power mode to optimized
4. Resolution to FHD
5. Disable all Bixby related apps using above software
6. Brightness to Auto
in Battery setting, check if any unusual rogue apps are consuming your battery than usual.
TheExpendble
Galaxy Note
s
