Note 10 Lite overheating & rapid battery draining
(Topic created on: 3/21/20 5:06 PM)
JayZee1986
Galaxy Note
My device Note 10 Lite overheats while simple browsing.  Battery life is very frustrating. Drains so rapidly. Disappointed about choosing this device.
10 Comments
nipoo
Galaxy Note
How about your signal condition in your area with 3G and 4G?
JayZee1986
Galaxy Note
I'm using wifi most of the time. Still this heats up rapidly & battery drains fast.
nipoo
Galaxy Note
Doesn't matter WiFi. At the same time, you have a connection with the low signal condition it may cause to battery drain. Also, it may happen because of background apps and their usage. Ex: Location service.
If all things are normal it will be a software issue. If it is a software issue Samsung will correct from updates.
But better to check from the nearest service centre.
JayZee1986
Galaxy Note
Thanks alot,buddy.
nipoo
Galaxy Note
You are welcome
Thanubro
Galaxy Note
it because exynos 9810 chip.it is a trash.same problem with my note 9
JayZee1986
Galaxy Note
Yeah...Buddy...this processor seems power hungry. Didn't know that before buying this phone. What to do now. 😐
Thanubro
Galaxy Note
i am looking for switch to the upcoming iphone 12😊
KKSSROSHAN
Galaxy Note
check the device from a authorized person. heating may occur due to weak signals, short circuit or may be due to background apps running or virus infected to run in background....clear your files or reset the phone and see..if not meet a authorized person to check... 👌
