NOTE20 ULTRA Battery drain
(Topic created on: 10-21-2020 09:32 AM)
toolana
Galaxy Note
I bought a note20 ultra exynos version last week and man The battery drain. When the phone is idle I loose like 3 percent of battery WHY IS THIS 😭
13 Comments
Cheers_bruh
Galaxy Note
May bee.......
Too much of background processes (too many syncing apps)
mobile signals
How long could your phone hold from 100 to 0% (screen time??)
exynos is bit power hungry than snapdragon equivalent (☺you knew it)
toolana
Galaxy Note
I didn't measure tbh and I couldn't get my hands on snapdragon cause I live in Sri Lanka but I have to charge the phone atheist twice a day
Cheers_bruh
Galaxy Note
Charging phone twice is unusual(something is wrong),average mid rangers also runs about 1 1/2 days
toolana
Galaxy Note
yea thats what
toolana
Galaxy Note
idk im so sad ryt now any way to reduce this
Cheers_bruh
Galaxy Note
I don't know well about flagship software skins! Far as my knowledge try these!
Settings-Battery- medium power saving
-enable extended battery level 3
Turn off auto sync
put some non urgent apps in to sleep or restrict background process of them !
But to know these may reduce performance but will not much on a considerable (unnoticeable) amount!
You might know about Dark mode.
Adaptive battery (on)
Put unused apps to sleep (on)
For sure there might be more helpful solutions going with high end device (Wonder around 🧐 you might find )
But its natural to feel so much disappointing in new but after you will feel very good and will feel Its a great device (common situation)(might not for your situation!☺)
There are so many here with best knowledge and experience so they could definitely help (I'm not much!)☺
toolana
Galaxy Note
thx man but I have done all of this. maybe the software updates will do something
nipoo
Galaxy Note
So do you want a phone with no battery drain in idle? That kind of a phone does not exist bro.
toolana
Galaxy Note
the battery drain is high here
