Docwill
08-19-2019 04:51 PM in
Galaxy Note
How do I get the led light indicator on the note 10 plus
5 Comments
KhalH8
Beginner Level 3
08-19-2019 07:06 PM in
Galaxy Note
There is no led indicator in any of the new full screen (infinity) phones
Docwill
08-19-2019 07:35 PM in
Galaxy Note
thanx for ur reply
JimmyA
08-19-2019 07:10 PM (Last edited 08-19-2019 07:12 PM ) in
Galaxy Note
Hey Docwill, you need to wait a bit for an updated version of the edge lighting +.
The current version works on the s series and uses the camera border as LED Notification. I seen it work on s10+ and s10e. I downloaded it yesterday and it says not compatible with my device. Since the phone was released yesterday, developers will now have time to work on the apps. I will post a link once it's out.
It's similar to this below, check it out to know what's coming.
https://youtu.be/_ub2n2WAN1I
Docwill
08-19-2019 07:36 PM in
Galaxy Note
thank u so much Jimmy for the valuable input, I have seen developers made it happen in s 10 through an app called Good lock however it's not available in UAE. will wait and see if they will release an update . to me the led indicator is an important feature.
JimmyA
08-19-2019 07:52 PM in
Galaxy Note
You're welcome, and if you ever can't find an app on the store, go to google, type for example 'good Lock apk download' and voilà. You will need to allow installation from unknown source in the security. That's how I'm getting the apps that are not here in the uae or any market. Cheers
