Is there anyone who face problem with their Note 8 camera.
(Topic created on: 08-17-2018 03:13 PM)
PrasadNarvekar
Galaxy Note
I noticed that the colours are dull using note 8 camera as compare to cameras like J8 & S8. also when we use note 8 camera In very bright light conditions it seems they are getting shadows of the light rays on screen which affect of not having clear and sharp camera quality also as I said color depth is very poor for both front and rear.
admin_
Galaxy Note
We do regret for the inconvenience caused. Let me recommend some steps to further isolate and determine the issue faced by you in your device.
- Check the Picture size (Camera Capacity) in camera setting (It should be Max according to Camera Capacity).
- Turn on the Auto Flash (If Available in the Device).
- Reset the Camera (From the Camera Setting).
- Software update via FOTA, Kies or SMART Tool.
Be sure to hit ♡ when you find an answer that works for you. For further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
