Huge battery drain after oneui 4 update on Samsung Note 10 plus
(Topic created on: 01-17-2022 07:35 AM)
VINOD418
Galaxy Note
Why every time samaung pushes the update with battery drain issue..it seems testing has not been done properly..
5 Comments
Nealph
Galaxy Note
Not in my case. Format phone once after taking backup.
karan2020
Galaxy Note
sidiculous
Galaxy Note
Any major update requires you to calibrate your battery as it reports erroneous levels. On the stock dialer, dial *#9900#, scroll down and tap 'reset battery stats'. Discharge completely before you recharge a couple of times, and when you recharge, try to charge continuously for 6 hours. Do three to four cycles of this, and you should be back to normal. Or if you want to skip the complicated stuff, just factory reset the phone and start fresh.
cs-member13
Expert Level 4
Galaxy Note
Dear Samsung member,
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Warm regard,
cs-member13
Expert Level 4
Galaxy Note
Dear Samsung Member,
We acknowledge your query and apologize for the same. To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
