TheBigD
Galaxy Note
Immediately after upgrading to 11 and UI3 my batter is draining in hours without any additional use (Note 10 plus). Device care is reporting issues with all apps.. very high background battery usage. Most are in sleep but 64 cannot be optimised. Any suggestions?
4 Comments
Not applicable
Galaxy Note
it's because may you simply install software via mobile data or wifi where the recommended process is to flash that big firmware from service center or install software via smart switch and pc to avoid software loop holes which creates thousands of different issues like battery drain , poor camera performance, slow ui etc
Jt2003
Galaxy Note
The same problem occured in my device once.
It resolved once I factory reset my device
and that is the only option.
edit: I also replaced my battery which is a waste of money.
Factory reset is the only option.
Advise : Do not update your device immediately after the update was released.
Wait for a few days to get information about bugs.
SaiKiranYaski
Galaxy Note
same problem brother. my screen on time is almost dropped to just 2hrs
Samsung_Support1
Galaxy Note
Dear Samsung Member,
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
