High Heating and Quick Battery Drain issue in Note 10 Lite
(Topic created on: 10-20-2021 10:26 AM)
AnilKM
Galaxy Note
This is a product review of Samsung Note 10 Lite which I am using since last one (01) year and I can say it is Not A Good Phone.
1- High heating issue even for 2 mins on call
2- It heats like a heating machine
3- Battery drains out 100% to 10% in 7-8 hrs
4- Worst experience after investing 35,000 for a phone which don't deserve it.
5 Comments
Galaxy Note
Have you updated your phone recently??
I guess that problem issued after update... this problem can solve very easily.
"Goto setting > general management > reset > reset all settings" then restart your phone.
All problems will be solved easily. No any data loosing. It's very safe. 👍 just your setting will be default and new.
Try it 👍 I also faced this problem. And solved through that steps.
AnilKM
Galaxy Note
No dear, I already did al these things. Even the board and battery replace twice....Then also I am facing same heat and battery drain issue
Galaxy Note
Then, It's processor's issue...
Galaxy Note
Dear Samsung Member,
We acknowledge your query and apologize for the same. Please visit this mentioned link to resolve your device heating issue: https://www.samsung.com/in/support/mobile-devices/why-the-device-heats-up-during-use/
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
Sami2
Galaxy Note
Did u fixed it?
