Galaxy Note 10+ Battery Drain After Android 10 Update
(Topic created on: 03-07-2020 12:59 AM)
AdyK
Galaxy Note
My battery just started to drain fast after the Android 10 update is anyone else also facing this issue? I used to get 8 hours of screen on time now I only get 5
12 Comments
cybertron129
Galaxy Note
correct
hashirajaz
Galaxy Note
it will get fine within a week or so...
AdyK
Galaxy Note
how do you know?
hashirajaz
Galaxy Note
I also have the note10+, that's the reason.
AdyK
Galaxy Note
ohh okay
khan755
Galaxy Note
plz tell me charging timings note10+ 0%to100%
AdyK
Galaxy Note
any news on how and when it will get fixed M
hashirajaz
Galaxy Note
it will get fixed overtime, just relax your mobile will automatically optimize the battery as per your usage pattern.
luizmt1
Galaxy Note
My Note 10 is still draining the battery. It drains more than 10% within less than 30 minutes, since the last update. I uninstalled most of the recently installed apps, but it didn't work. I'm starting to regret buying Note 10 because of such an annoying issue.
