Voodoo
06-18-2020 01:46 AM (Last edited 06-18-2020 01:48 AM ) in
Galaxy Note
Hi .. this might seem to be an old issue. But recently i am not able to unlock my phone using the finger print sensor. Its shows the error as finger print sensor not responding try again later. Well went i checked in the settings and tried to get to the biometrics section in order to change. This message popped out
I did try restarting but no use. I tried the finger print test and it was a fail.. like it showed no data found. But in the biometrics there were fingerprints registered previously. I am wondering if this a software prob. I obviously dont wanna do a hard reset which will wipe out all the info and data as this is my main driver. And i dont wanna replace the sensor. Is there a solution for this... ? Plz help me out
Solved! Go to Solution.
10 Comments
- « Previous
- 1
- 2
- Next »
Samsung_special ist
06-21-2020 05:47 PM in
Galaxy NoteHey there,
Please visit the nearest service center for the phone to be checked by our team.
https://www.samsung.com/ae/support/service-center/
Thank you
- « Previous
- 1
- 2
- Next »
