Finger print problem...
(Topic created on: 01-27-2023 03:08 AM)
kamanyola
Galaxy Note
I have a similar problem with finger print I have to almost put my finger 4 to times to open my phone but not successful every time! In the end I have to log in using my pin number?
Any solution to this problem?
My phone is Galaxy Note 20 Ultra 5G.
6 Comments
Galaxy Note
Try re-adding your fingerprint and check 🙈
kamanyola
Galaxy Note
Galaxy Note
Typo, I meant re-add. I corrected it 🙈😂
VikrantTambade
Galaxy Note
Did you put screen guard recently?
You can enable the touch sensitivity in display settings. It should solve your problem.
Good luck 👍
kamanyola
Galaxy Note
Yes I have but they is a hole for finger print...
shiv7688
Galaxy Note
Just do one thing ....... Register any one finger multiple times. Like if there are 4 fingers you can register then just register 2 fingers but each one 2 times. This will solve your problem.
