Highlighted
Dilshan77
How to check bluetooth headphones battery level? There are 3rd party apps but isn't that great so is there any solution to get it on my note 9? Thanks
4 Comments
Highlighted
MittuVichu
On new devices its visible from the Bluetooth Settings Menu.
Just long press the Bluetooth quick setting tile, it will take you to bluetooth settings. from there you can see the connected device list and battery percentage.
Highlighted
Dilshan77
Is it for samsung bluetooth devices only? cause I use a JBl headset
Highlighted
MittuVichu
Its available for all bluetooth devices running on bluetooth 4.1 and above.
Highlighted
Dilshan77
oh ok may be that's the issue, my jbl headset is bluetooth 4.0 anyways thanks for the information.
