Hello guys,
I am experiencing an issue with my Galaxy note 20 5G, Android 11.
The battery drains from 10% to 0% (shut down) in just a few minutes.
All suggested attempts to improve/diagnose the issue do not work.
Any suggestions before dropping the phone to a Samsung Assistance shop?
Thank you,
Massimo
thank you for your comments. someone is suggesting battery recalibration. is that an option? is that safe?
someone suggests with *#0228# on dial pad ... not sure this is safe or the solution. It might try to reset the phone first?
Thank you. I have factory reset. By tonight I will know if the issue is fixed or not. thank you for your help
