Battery issue after new Battery
(Topic created on: 06-21-2024 06:16 PM)
Wrymnihilus
Galaxy Note
I got the battery replaced just 2-3 days ago from a samsung authorized service center and the battery issue is still showing up, all service centers say they have no idea, all recommending factory data reset and i have done that more than 10 time and the issue is still there. What to do? (*#4636#*#*) this test menu is not opening.
14 Comments
MR_PRIME
Galaxy Note
You'r close to complete the battery charging cycle that's why!
Wrymnihilus
Galaxy Note
But how do i reset it ? Service centers have no idea
MR_PRIME
Galaxy Note
As of my Experience you'll have to replace your battery...there'r no any option instead of that
Wrymnihilus
Galaxy Note
That's the thing, i verified the that battery is new, the one that was installed during the replacement.
MR_PRIME
Galaxy Note
May be there might be problem in PCB.
Ask service center to check it out properly. That's the main reason of your cause
rejiab
Galaxy Note
try *#9900# to reset the battery
Wrymnihilus
Galaxy Note
Tried it, followed all the steps accordingly but still the problem persists.
rejiab
Galaxy Note
Connect cc thru remote management. They will examine it let you know what to do
cs_member10
Galaxy Note
Dear Samsung Member,
We would request you kindly contact the dedicated WhatsApp helpline ( 1800-5-7267864 Operations 24*7 ) they will guide you with the exact information regarding this.
