AjayajuAjay
01-23-2019 11:49 PM in
Galaxy Note
My Note 9 very new ..only 9 hours and showing 40% battery remains. Is it normal ..please advice
3 Comments
Chaos1
01-24-2019 09:08 AM in
Galaxy Note
If you maxed out your performance and data usage, all sensors on along with excessive app usage and and display set at max brightness. That's possible given all or most of the aforementioned conditions are present.
ishimo
01-24-2019 06:15 PM in
Galaxy Note
Same problem
Magr
02-06-2019 02:11 AM in
Galaxy Note
same problem. even with the power saving mode on , I got only 17hours and it's when I had 100% battery life. but if I use wifi and watch YouTube or music n check camera for 2 hours or less. it's already less than 40%
