Highlighted
Battery life on android 9 was far better than android 10. I'm not even getting 4hrs of SOT.
9 Comments
Highlighted
You battery need calibration. Best thing is let you phone discharge battery fully then recharge to full 100 percent. This cycle will re calibrate you battery and petformance will improve. Also during night put your phone battery to medium optimization. In morning you can switch back to optimized. Hope this solution helps.
Highlighted
Will try this, thank you 😁
Highlighted
if you see any improvement let us know in here and do press 3 dots as solution for others to know. cheers
Highlighted
Yeah sure
Highlighted
after android 10 update, if you haven't reset your phone then please reset it . If possible hard reset it . It will make your phone more smooth and lag free . You will see improvement in battery life too
Highlighted
from last few dates I'm not able to make it through full day with more then 20% at the end
Highlighted
Battery drain was horrendous on Android 10, only got 3 or 3 and a half hour SoT.
Tried wiping cache
Tried factory reset
Tried changing the battery saving modes
Although phone was running smooth, but in relation to the battery nothing helped. Over the weekend I rolled back to Android 9. Finally I have a solid battery again and all the issues gone away.
I do think Samsung has massively dropped the ball with Android 10 upgrade killing the awesome battery performance of this phone. I am not likely to upgrade to Android 10 any time soon
Highlighted
Menyheart. I wish I could roll back but i updated the feb 2020 security patch update and it has changed the bootloader to 4. earlier was 3. Now I cant go back.
Highlighted
Hi please sign the petition for Note 9 series before you loose the oppurtunity for getting great features
https://www.change.org/p/change-org-to-get-what-we-deserve
