Battery drain Note 10 plus
(Topic created on: 02-05-2021 12:56 AM)
Rami1234
Galaxy Note
I recently brought Note10 plus and the battery is draining while use. Screen on time is only 4 hrs.
Any option and help would be appreciated
Thank you
8 Comments
janefrr
Galaxy Note
am using this almost 1 year 3 months its battry is very good... daily use 4 to 5 hr youtube and other social apps.. i put optimised battery... use power saving mode...
Rami1234
Galaxy Note
hi. is there anything you do to save battery. do you get full day battery ?
Rami1234
Galaxy Note
thanks
Rami1234
Galaxy Note
Hi. you can see the graph going down. yesterday i got OSD for 4 hrs for a full charge
Galaxy Note
Give it 3 days or maximum a week as the AI is learning your usage, it will optimise itself. My Note 10+ was bought the time it released and I'm getting solid 8-9 hours SoT
Rami1234
Galaxy Note
thanks for your positive response. did you face this issue. thanks
Galaxy Note
Yes it happened when I bought the device as well. Back to my previous post it should be sorted don't worry 👍
Rami1234
Galaxy Note
a big relief.thanks
