Battery and overheating issue
(Topic created on: 06-17-2022 11:13 AM)
sarathscbs
Galaxy Note
Completed update of Samsung one UI 14 my Note 10+ lost it's battery back up and my device is getting overheated while using mobile data and camera. So I went to the nearby service centre and check my device and they found that there are no hardware issues but they told me to reinstall the OS. So I did that. Then the issue persisting so I changed the battery at my own risk. But the issue persisting. But now I am happy that I can easily iron my linen shirt and jeans once using mobile data or a camera. I know that Samsung intentionally doing battery backup failures through software after mocking APPLE. Please not that I checked my device completely in Samsung authorised service centre and changed the batter. So it was completely a software bug created by Samsung intentionally and this is not fair.
8 Comments
rahulbudidi
Galaxy Note
Then wait for the next update
sarathscbs
Galaxy Note
From the lastm last 4 updatesate I am waiting for that but the issue is not resolved
rahulbudidi
Galaxy Note
Format your device and don't install any third party battery consuming apps and wait till the next update, then install any app you want
sarathscbs
Galaxy Note
Format twice... I don't use any unwanted apps on my phone
rahulbudidi
Galaxy Note
Then simply throw it and buy some other brands if interested
sarathscbs
Galaxy Note
I am also thinking same way
Ab_Heartsy
Expert Level 3
Galaxy Note
Also if possible read my post about One UI tips n try to follow those tips if possible, it might improve your situations but is a temporary tip😊👍🏼
sarathscbs
Galaxy Note
Thanks brother
