Highlighted
BATTERY DRAINS SO FAST ON NOTE 9....SAMSUNG PLEASE FIX THE ISSUE IN NEXT SECURITY UPDATE...
6 Comments
Highlighted
it is never fixed in security updates. It also depends upon usage and pattern of individual use. Best solution is put few apps to sleep that are open in background. Use medium optimization at night.
Highlighted
I am trying to update software for my galaxy A10S
But it's saying your current software is not supported to update and contact with your customer care
What is the reason
Highlighted
bro....you can restrict background activities of the apps
Highlighted
Issue fixed after feb security Patch...Thnks guys for yur suggestions anyways...👍
Highlighted
Hi there,
To resolve the issue please follow the troubleshooting steps provided in the given link: http://www.samsung.com/in/support/skp/faq/1101689
Regards,
Team Samsung Members
Highlighted
What is the reason
