Highlighted
Ritte
Bought a Note 10+ from one of our telecom service providers on September 30th. But the battery Drain on my device is abnormal... I have noticed that whatever device I buy has always had this problem... is there something wrong with my unboxing or something... I have used S5, s7 edge, note 8, s9+ and note 10+... All have battery Drain issues... "tested with other users"
7 Comments
Highlighted
Muhammadh9
Beginner Level 3
same
Highlighted
alex60
So as your experience how long have been taking note 10+ battery ?
Highlighted
Ritte
less than 6 hours give or take... if we are talking about constant usage... it goes from 100% to 90% after 30mins of game time whereas another note 10+ only had 4% reduction
Highlighted
alex60
seriously its a huge battery drain. any solutions there ?
Highlighted
thusharara
I have been using Note10+ since September but I didn't get that issue.
please check the battery usage.
Highlighted
thusharara
I use around 14hrs
Highlighted
dilum
i think its normal try to reset your device
