ManashPatra
11-22-2018 09:49 PM in
Galaxy Note
Airtel VoLTE is not working properly in Note 9 Kolkata region. Where as Xiomi phones are working properly. Same airtel SIM showing VoLTE in xiomi note 5 pro phone, but not showing in my Note 9. Is it problem with Note 9?
6 Comments
re1th
11-23-2018 05:30 AM in
Galaxy Note
did u change u r network mode to volte..?
ManashPatra
11-23-2018 08:41 AM in
Galaxy Note
Network mode set to LTE/3g/2g. Volte setting is also enabled. 4g is working but VoLTE is not showing
offroader
11-24-2018 02:41 AM in
Galaxy Note
same issue with me too. in jalandhar
offroader
Galaxy Note
any solution
admin_
11-24-2018 06:45 PM in
Galaxy Note
Thanks for being with Samsung and for sharing your Concern. Let us recommend some steps to further isolate and determine what you are experiencing. Please be aware that device speeds may vary based on multiple outside factors. We would like to suggest you kindly follow the below mention steps to overcome the Issue:-
1) Ensure that network frequency of your device should be selected on Auto-mode.
Menu>Settings> Connections>More Networks> Mobile Networks> Network Mode> Select Auto mode (GSM/WCDMA/LTE).
2) Search for the Network Manually by the steps as mentioned:
Menu> Settings> Connections>More Networks> Mobile Networks> Network Operators> Select Manual Search.
3) You may check by exchanging the SIM in SIM slots.
4) Insert different SIM card in your mobile and check if the issue is resolved or not.
If still issue persists then we would suggest you to once contact with your service provider.
Be sure to hit ♡ when you find an answer that works for you. For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
GalaxyTeam
11-25-2018 09:53 AM (Last edited 03-14-2019 02:19 PM ) in
Galaxy Note
