01-22-2021 12:18 AM in
Galaxy MHello, i am new to M51, got it yesterday. First question: is it normal that no led or other light are showing notifications?if i get for example a watsapp msg, is it notmal that phoe does not have any light blinking?
Then AOD, i have set it on, but if my phone is on the table is always all black. If i tap it then i can see the time and the notification displayed.Is that normal?I want it always visible...
thank you
Solved! Go to Solution.
01-22-2021 01:38 AM (Last edited 01-22-2021 01:38 AM ) in
Galaxy M- Mark as New
01-22-2021 12:25 AM in
Galaxy MFor AOD, open settings in phone and search always on display. So, you got the option. customize accordingly suitable to you.
01-22-2021 01:32 AM in
Galaxy Mcan you explain me why because of amoled there is no need of led?
01-22-2021 12:37 AM in
01-22-2021 03:21 AM in
Galaxy Mgo to settings>accessibility>advanced settings>click on flash notification
01-22-2021 01:49 PM in
Galaxy Mi have tried to enable this from accessibility, but it seems nothinh happen actually. i don t see any led on when notifications are present
01-22-2021 01:54 PM in
01-22-2021 03:26 PM in
Galaxy Myes, i have done that. Inoticed that flash light worked, but when the screen is on, not when is off. When is off, no flash , neither small led around the camera work
01-22-2021 08:30 AM in
Galaxy M
