Highlighted
My new galaxy m30s battery drain a lot please give me solution.
18 Comments
Highlighted
Highlighted
Wait for next update samsung defently slove bro also send feedback samsung all m30s user faced
Highlighted
bro I remembered u said earlier that you are not facing battery drainage issues
Highlighted
not me but my friend here also drain issue some members here also facing becuse i update last with smart swtich
Highlighted
may be next update solve this
Highlighted
Highlighted
how to get this kind of great bb??
Highlighted
just charge with normal charging instead of fast charging and dont use mobile while charging
Highlighted
yes that is the issue ,hopefully fixed with next update but at the same time check these settings u did or not and if not then as of now u can do these
and observe is there any improvement
the setting are;
1. Connection>more connections settings> disable nearby device settings
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
3. Google >click on 3dot>usage and diagnostics >off this option
4. developer option >background limit>no background processes.
5. Long press on each app specially 3rd party and rarely used app>app info>
6. Device care>battery >select "optimised and adaptive power saving.
Steps to enable developer option
settings >about phone>software information >then u find build number >tap 7 times>then back to settings
and at end of settings one new option called developer option
click on it and find that option
