09-27-2020 04:39 PM in
Galaxy M- Mark as New
09-27-2020 04:52 PM in
09-27-2020 05:14 PM in
09-28-2020 12:47 AM in
09-27-2020 05:20 PM in
09-27-2020 05:24 PM in
06-14-2021 06:40 PM in
09-27-2020 05:36 PM in
Galaxy M1. Connection>more connections settings> disable nearby device settings
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party(LIKE FACEBOOK, INSTA,YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> then go to these 3 options below on by one
5. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery?)
6. If you use Facebook frequently then disable "auto play video"
09-27-2020 07:40 PM in
09-27-2020 07:44 PM in
Galaxy M
