battery and heating issue
(Topic created on: 06-24-2020 12:07 PM)
Kishanpars76
Galaxy M
I have Galaxy M30s UAE .
It is taking 6 to 7 hours to charge after android 10 update.
Fast charging is enabled but no solution for this.
It also have high heating issue after that.
In India this problem is solved by a security update of approx. 150 Mb .
I hope Samsung will help.
6 Comments
AVENGERS123
Galaxy M
turn on flight mode for fast charging then remove the cover then charge and say how is it
Kishanpars76
Galaxy M
this worked for 4 to 5 days but not now ..
AVENGERS123
Galaxy M
is this helping?
MohammedSijah
Galaxy M
Check for any solution after wiping your cache partition.
Also check what happens, if charged after switching off the device. Please share with us your results.
Samsung_specialist
Galaxy M
Hello there,
Battery percentage may vary according to the usage (internet, call, video playback, etc..). However, if you feel that the device battery drains quickly when no function is used, please send the device to one of the service centres to discover and fix the problem. www.samsung.com/ae/support/servicelocation/.
Thank you
Samsung_dJZ2VaK
Galaxy M
no to vmkc
