Usb connection problem
(Topic created on: 08-03-2022 08:01 PM)
PrakashYTYadav
Galaxy M
I am unable to connect my samsung smartphones with my laptop using data cable.
4 Comments
Galaxy M
Bhai problem solve nahi hua hai isscode se bhi
ganesh908
Galaxy M
First go to developer option then scroll down to defult USB configuration then choose what you want to do.
If not work try with another data cable.
Galaxy M
I have done that settings and i have used another data cable it is not showing only it is charging
