Samsung m35 5g battery drain
(Topic created on: 12-01-2024 04:04 PM)
Vivek5665
Galaxy M
My Samsung m35 5g is draining battery very fastly. It is provided with 6000mah battery but it is not performing like 6000mah. I bought this phone in November 2024. Anyone are facing this issue tell me.
14 Comments
Vivek5665
Galaxy M
What was their response
Galaxy M
They said troubleshooting and nothing massive change
cs_member10
Galaxy M
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
● Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
→ Update the software if available: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
→ You can reset your device by following the steps.
If the issue still occurs, please visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
Vivek5665
Galaxy M
What should i do now wait for next update or should i vist samsung service center again can any one say
manzarkhan
Galaxy M
Bhai mere M35 me v battery drain bht fast ho raha tha par update check karo abhi update aa gaya hai update karne ke baad mera battery drain issue fix ho gaya aap v update karlo bhai 🥰
