Samsung galaxy m31 restart problem while using
(Topic created on: 06-11-2021 01:24 PM)
galaxy123
Galaxy M
My samsung galaxy m31 get restart while using .I have using since July 2020 there is no problem like this but near one month it creates problem.unless everything is right
42 Comments
garv_hr36
Galaxy M
I have also faced this problem in feb,march but in march due to ota update now its fine.
Check weather your phone software is updated or not.
NabenduS21FE
Galaxy M
Either some 3rd party apps you installed currently or through some websites also this can be happened..so if u still facing without this then you can reset your device or wait for next ota update as currently under testing and releasing within a week..
vickycheeku
Galaxy M
I have also same problem in m31.when we expect next update
NabenduS21FE
Galaxy M
As the last firmware was fixed on june 2nd with a build number BUF1 so we can expect within two weeks from that day...so within 15th to 20th june surely M31 will get an ota update as well as M21 along with F41 as their build no is also same as M31...
vickycheeku
Galaxy M
Thanks for your update 👍
NabenduS21FE
Galaxy M
Always welcome😊
sharadpatil20
Galaxy M
HI Team,
I am still facing Samsung M31 restart issue.
I have latest update.
Please suggest, now it is irritating and it is mostly restart while using Camera.
Thanks,
Sharad Patil
9820459476
ameen7
Galaxy M
Same problem while using camera stuck then suddenly automatically restart
Aslam_PSA
Galaxy M
M31s restarts while using camera stuck then suddenly automatically. kindly suggests the best solution. Its irritating and annoying.
