Samsung One UI 7.0 Update Major Problem πŸ‘‰ Battery Drain πŸ₯΅πŸ”‹ πŸ˜’
(Topic created on: 06-12-2025 11:34 AM)
Vinay_2004
Galaxy M
How to Fix this Rapid Battery Draining πŸ”‹ Major issue of One UI 7.0 Update after Installing it πŸ“²
Most of the Galaxy Users are Facing this issue β€ΌοΈπŸ˜‘πŸ€”
Samsung Should Looks seriously into these Major issues of One UI 7.0 Update ASAP ‼️ and fix these issues by Providing another Software security patch Updates πŸ™„ πŸ™πŸ™
5 Comments
goodthings
Galaxy M
UserAdik
Galaxy M
I have already reported πŸ™πŸ˜Š
Vinay_2004
Galaxy M
Thanks bro πŸ˜ŠπŸ™
UserAdik
Galaxy M
cs_member10
Galaxy M
Dear Samsung member,
9. Reset the device:
IMPORTANT:
β€’ Kindly create data backup of your device via SMART switch mobile application or http://www.samsung.com/in/support/smartswitch pc suite.
β€’ Remember google password before resetting the device because it is required during initial setup.
β€’ If you do not remember it, then reset, (Forgot password) your google account.
β€’ For this:
β€’ Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select ""try another way"" > Next > Enter a new password > Next
