01-10-2025 09:45 PM in
Galaxy M- Mark as New
01-10-2025 10:06 PM in
01-10-2025 10:52 PM in
01-10-2025 11:10 PM in
01-11-2025 09:11 AM in
Galaxy MDear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
● Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
→ Update the software if available: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
→ You can reset your device by following the steps.
If the issue still occurs, please visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
01-12-2025 01:26 AM in
Galaxy M
